Zum Hauptinhalt wechseln
How to Manually Eject a Stuck Disc in a PlayStation 5
Was du brauchst
  1. How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: Schritt 1, Bild 1 von 3 How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: Schritt 1, Bild 2 von 3 How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: Schritt 1, Bild 3 von 3
    • Unplug all cables going into the console (power, ethernet, hdmi and etc).
    • This should be done for your safety and for the safety of the device.
  2. How to Manually Eject a Stuck Disc in a PlayStation 5: Schritt 2, Bild 1 von 3 How to Manually Eject a Stuck Disc in a PlayStation 5: Schritt 2, Bild 2 von 3 How to Manually Eject a Stuck Disc in a PlayStation 5: Schritt 2, Bild 3 von 3
    • If you are using a stand to hold your PlayStation, locate the screw at the bottom.
    • Using the flathead screwdriver, unscrew the 5mm Phillips screw from the base.
    • Remove the base, and place it off to the side.
  3. How to Manually Eject a Stuck Disc in a PlayStation 5: Schritt 3, Bild 1 von 3 How to Manually Eject a Stuck Disc in a PlayStation 5: Schritt 3, Bild 2 von 3 How to Manually Eject a Stuck Disc in a PlayStation 5: Schritt 3, Bild 3 von 3
    • Place the PlayStation on the side without the PlayStation logo.
    • Pull up on the top right corner of the PlayStation . This corner can be found diagonally across from the disc tray. Pull the cover toward the disc tray, in a diagonal direction.
    • To remove the white cover, it may take some force.
  4. How to Manually Eject a Stuck Disc in a PlayStation 5: Schritt 4, Bild 1 von 2 How to Manually Eject a Stuck Disc in a PlayStation 5: Schritt 4, Bild 2 von 2
    • Poke a hole through the black sticker with the Philip's head screwdriver or spudger.
    • Use the screwdriver as a key to turn the screw inside the black sticker clockwise.
    • The disc should come out after several turns.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jason Pinto
121 Reputation
1 Anleitung geschrieben
York University, Team S2-G18, O'Regan Winter 2021 Mitglied von York University, Team S2-G18, O'Regan Winter 2021
YORK-O'REGAN-W21S2G18
1 Mitglied
5 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 4
Letzten 7 Tage: 48
Letzten 30 Tage: 255
Insgesamt: 2,365
