Zum Hauptinhalt wechseln
How to Mend Broken China
Was du brauchst
  1. How to Mend Broken China, How to Mend Broken China: Schritt 1, Bild 1 von 1
    • Wipe all broken edges with rubbing alcohol using a paper towel.
    • Do this to eliminate any grease and dirt.
    • Be aware that rubbing alcohol is highly flammable.
    • Be aware of sharp edges throughout this repair.
  2. How to Mend Broken China: Schritt 2, Bild 1 von 1
    • Pour epoxy into a smooth-surfaced container.
    • We used the plastic wrapping of the razor, but any container works.
    • Don't use epoxy in a small, confined space.
    • Do not get epoxy near eyes or on skin. Consider using polyethylene or polypropylene gloves.
  3. How to Mend Broken China: Schritt 3, Bild 1 von 1
    • Mix epoxy fluids with a toothpick.
    • The fluid sets in 5 minutes, so you must quickly apply it to the china. You can mix more if the first pour hardens.
  4. How to Mend Broken China: Schritt 4, Bild 1 von 2 How to Mend Broken China: Schritt 4, Bild 2 von 2
    • Apply the epoxy along the edges of the base piece of china and first chipped piece of china using the toothpick.
  5. How to Mend Broken China: Schritt 5, Bild 1 von 3 How to Mend Broken China: Schritt 5, Bild 2 von 3 How to Mend Broken China: Schritt 5, Bild 3 von 3
    • Attach the first detached piece to the base carefully by hand.
    • Adjust as needed.
    • Don't worry about excess epoxy at this point. It will be removed after setting.
  6. How to Mend Broken China: Schritt 6, Bild 1 von 2 How to Mend Broken China: Schritt 6, Bild 2 von 2
    • Apply epoxy on the next detached piece and the already mended piece
    • Use a tweezer to attach smaller fragments.
  7. How to Mend Broken China: Schritt 7, Bild 1 von 2 How to Mend Broken China: Schritt 7, Bild 2 von 2
    • Attach the piece to the china.
    • Adjust as needed
    • Repeat the process of applying epoxy and attaching the chips until all broken pieces are successfully in place.
  8. How to Mend Broken China: Schritt 8, Bild 1 von 1
    • Place mended china in a container of stabilizing sand or gravel.
    • This step is performed to put the right gravitational weight on the attachments so the pieces don't become unaligned during the setting of the epoxy.
    • Leave to set for at least 1 hour.
  9. How to Mend Broken China: Schritt 9, Bild 1 von 2 How to Mend Broken China: Schritt 9, Bild 2 von 2
    • Shave off as much excess epoxy as possible using the razor.
    • Exhibit caution when using the razors; they are very sharp!
  10. How to Mend Broken China: Schritt 10, Bild 1 von 2 How to Mend Broken China: Schritt 10, Bild 2 von 2
    • Use coarse sandpaper to further reduce the excess epoxy.
  11. How to Mend Broken China: Schritt 11, Bild 1 von 1
    • Use fine sandpaper to smooth out remaining inconsistencies.
  12. How to Mend Broken China: Schritt 12, Bild 1 von 2 How to Mend Broken China: Schritt 12, Bild 2 von 2
    • Darker cracks form where the clear epoxy functions as filler, but the cup will work perfectly fine! Add colored pigment to the epoxy for a more subtle repair.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
UC Davis, Team S1-G4, Coad Spring 2017 Mitglied von UC Davis, Team S1-G4, Coad Spring 2017
UCD-COAD-S17S1G4
3 Mitglieder
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 47
Letzte 30 Tage: 173
Insgesamt: 20,153
