1. Remove battery cover, pushing down on circled areas and pushing outward Remove battery by lifting up on corner exposed by indent in case
    • Remove battery cover, pushing down on circled areas and pushing outward
    • Remove battery by lifting up on corner exposed by indent in case
  2. Use a J0 screwdriver head
    • Use a J0 screwdriver head
    • Remove 3 screws from battery compartment
  3. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  4. Open connector port on side Remove screw with PH00 screwdriver head
    • Open connector port on side
    • Remove screw with PH00 screwdriver head
  5. Use plastic opening tool to pry at the open slits on the side. One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly. Also the plastic connector door will fall off. It will need to be put back upon reassembly.
    • Use plastic opening tool to pry at the open slits on the side.
    • One or two silver foam cubes may pop out of the device. These belong in the slots shown in the third picture. They do not need to go back until reassembly.
    • Also the plastic connector door will fall off. It will need to be put back upon reassembly.
Abschluss
Keegan Williams
165 Reputation
2 Anleitungen geschrieben
Ohio State, Team 1-5, Garvin Spring 2016 Mitglied von Ohio State, Team 1-5, Garvin Spring 2016
OSU-GARVIN-S16S1G5
3 Mitglieder
3 Anleitungen geschrieben
Will changing the battery reset the settings within the remote?
wiboman AT gmail DOT com
Wibo Lammerts - Antwort
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 13
Insgesamt: 506
