Was du brauchst
Open Terminal.
Log into an administrator account on your computer. Go to Applications → Utilities and launch Terminal.
Open the application's package contents.
Locate the application in Finder. Right-click (or Control-click) its icon and select Show Package Contents from the drop-down menu.
You should now see one or more folders inside the application. Locate the executable file inside this folder.
This is usually inside /Contents/MacOS.
Type sudo followed by a space. Do not enter the command yet.
Drag the executable file into the Terminal line.
This should automatically insert the file path to the executable file.
If you have questions, please leave a comment below. I will try to get to as many questions as I can.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
