Einleitung
Use this guide to open the Apple TV 4K 2021 Siri Remote for repairs.
Was du brauchst
Use a P2 Pentalope screwdriver to remove the two 6.1 mm-long screws securing the bottom cover.
Remove the bottom aluminium cover.
Insert an iFlex into the gap on the right side of the circular clickpad.
Use the iFlex to create a gap by prying the circular clickpad upwards.
Insert an opening pick into the gap. Remove the iFlex after inserting the opening pick.
Slide the opening pick around the top half of the clickpad.
Lift the clickpad from the lower right side to access the press connector.
Use an opening pick to pry up the clickpad connector to disconnect it.
Remove the clickpad.
Insert the iFlex into the gap on the right edge of the volume button.
Insert the iFlex about 3 mm.
Use the iFlex to pry up the volume button to unhinge the plastic clips which keep the button in place.
Remove the volume button.
Insert an angled probe into the housing to release the right plastic clip of the mute button.
Carefully push against the buttons clip from the inside.
Insert the probe into the gap on the surface of the mute button.
Use the probe to pry up the mute button and unhinge the remaining plastic clips.
Remove the mute button
Insert a probe into the case to release the right plastic clip of the play/pause button.
Gently press against the clip from the inside.
Insert the probe into the gap on the surface of the play/pause button.
Use the probe to pry up the play/pause button and unhinge the remaining plastic clips.
Remove the play/pause button.
Insert the probe into the housing where the clickpad was previously to release the upper plastic clip of the back button.
Carefully press against the clip from the inside.
Insert the probe into the gap on the surface of the back button.
Use the probe to pry up the back button and unhinge the remaining plastic clips.
Remove the back button.
Insert the probe into the inner housing where the clickpad used to be to release the upper plastic clip of the TV button.
Insert the probe into the gap on the surface of the TV button.
Use the probe to pry up the TV button and unhinge the remaining plastic clips.
Remove the TV button.
Use a T3 Torx screwdriver to remove the two 4.7 mm-long screws securing the Siri button on the right edge of the remote.
Use the pointed end of a spudger or a pair of tweezers to lift the Siri button up and out of the remote.
Remove the Siri button.
Turn the remote upside down.
Insert the flat end of a spudger into the charging port.
Push the spudger in to slide the insides of the remote out about 1 inch (2.5 cm).
Turn the remote back over and make sure that the recess of the inner frame aligns with the power button.
Use the pointed end of a spudger to press the power button into the recess of the inner frame (if it didn’t already fall in by itself).
Remove the power button.
Pull the inner frame out of its aluminum housing.
Repair didn’t go as planned? Check out our Answers community for help.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
Hi,
Thank you so much for the guide - I was able to open up my coffee spilled on remote clean it and actually fix it! However...somewhere along the lines I broke the Siri button (it was working fine prior to me opening up the remote)! It's a physical problem - I can't push it down physically, there is no spring like behavior...was there something in between the button that I dislodged? Any ideas?
May not be immediately clear from the photos, but to extract the two P2 Pentalobe screws, you'll need to hold the P2 bit about 10-degrees off-axis. The screws are not longitudinal to the case.
I found the screw heads to be extremely brittle, got them out once and inserted again but now I am seeing small shavings coming off and can't open it again, word of caution
