Einleitung
Here's a guide on how to patch a small hole in jeans using wool and a technique called needle felting.
Needle felting is a craft technique that uses special felting needles to intertwine wool fibers, creating a solid fabric. When used to patch a hole in jeans, the wool fibers not only bind together but also intertwine with the jean fabric, effectively patching the hole.
Was du brauchst
Make a loop at the end of the thread.
Pull the end of the thread through the loop creating a knot.
Grab the end of the jean with your hand.
Pull the jean towards you, making it inside out.
Place the felt on the hole.
Pinch together the jean and the felt.
Insert the needle horizontally into the jean and edge of the felt.
Pull the needle through till the knot touches the felt.
Repeat the above steps until the border of the felt is stitched.
Make a knot at the end.
Cut off excess thread.
Grasp the end of the jeans and pull them towards you to turn them right side out.
Insert the foam board into the pants and position it underneath the hole.
Grab more than enough wool to cover the size of your hole, ensuring it is at least an inch thick.
Rub the wool between hands to make a ball.
Place the wool on top of the hole.
Stab the wool through the jean and onto the foam board.
Repeat until the wool is hardened.
Rub some soap onto the wool to tangle the fibers.
Place the jeans into the laundry machine.
Wash on cold and air dry.
Wear your cute mended pants!
