Einleitung
A tear on your window screen renders the screen useless. But if the tear has not pulled the mesh out of the frame and/or is not extremely large, then a full replacement—which can be costly and labor intensive— should not be necessary. This fix will guide you through fixing a tear on a screen easily and cost effectively. All you will need are some scissors, pliers or tweezers, and some patching mesh.
Was du brauchst
Remove the screen from the window frame and place it in your work space.
From where the tear ends, measure one inch from the left, right, bottom, and top of the tear.
Measure your patch using the dimensions determined in step 2.
If the patch is larger than said dimensions, mark where you will cut it.
Use scissors to cut the patch to size.
Place your patch over the tear to confirm it extends one inch from every side.
Using the pliers or tweezers, remove some threads from two opposite sides of the patch.
Stop when approximately half an inch of threads are exposed on each side.
Center the patch over the tear.
Press the exposed patch threads through the screen.
Gently, but firmly, bend the threads back in the direction of the tear to secure the patch.
Do this for both sides, making sure the patch does not move around when both sides have been bent.
Check that the patch is secure and covers the tear well.
If the screen was removed from the frame, reinsert the screen back on the frame.
Your window screen is now patched. Feel free to once again open your window and let the breeze in without any pesky bugs or debris flying through the tear!
