Einleitung
These instructions will cover the techniques for measuring external & internal features, as well as heights and depths.
Was du brauchst
Use the metal wheel contacting the measured surfaces.
Make use of the locking mechanism.
Occasionally the device has to be positioned in a way that cannot be read.
Always prioritize comfort. If there is a change the jaws can move when attempting to read. Lock the device. Move it to you.
External features are measured as shown.
These sections of the jaws have a knife edge,
These sections have a flat edge.
Heights of steps are measured as shown.
Butt the head of the caliper against one surface.
Butt the head of the slider against the other surface.
Depth of holes are measured as shown.
Position the blade to the center of the hole.
Hold the end of the caliper flush the surface of the hole.
Extend the slider until the blade bottoms out the hole.
Happy Measuring
Happy Measuring
5 weitere Nutzer:innen haben diese Anleitung absolviert.
