Zum Hauptinhalt wechseln
How to Prevent a Run or Tear in Tights from Spreading
Was du brauchst
  1. How to Prevent a Run or Tear in Tights from Spreading, Run or Tear in Tights: Schritt 1, Bild 1 von 2 How to Prevent a Run or Tear in Tights from Spreading, Run or Tear in Tights: Schritt 1, Bild 2 von 2
    • Put the ripped tights on for easier repair, or leave them on if you’re already wearing them.
    • Gather clear nail polish and a pair of scissors.
  2. How to Prevent a Run or Tear in Tights from Spreading: Schritt 2, Bild 1 von 1
    • Locate all potential runs or directions that the rip can expand.
    • Runs will not usually expand horizontally, but be sure to check both vertical ends of the run.
  3. How to Prevent a Run or Tear in Tights from Spreading: Schritt 3, Bild 1 von 1
    • Gently tug the tights away from your skin to prevent the nail polish from affixing to your body.
  4. How to Prevent a Run or Tear in Tights from Spreading: Schritt 4, Bild 1 von 2 How to Prevent a Run or Tear in Tights from Spreading: Schritt 4, Bild 2 von 2
    • Brush a dollop of clear nail polish on all potential runs.
    • Small runs will require just a dab of nail polish while larger holes may require a thin coat.
    • Repeat these steps to all potential runs and loose threads.
  5. How to Prevent a Run or Tear in Tights from Spreading: Schritt 5, Bild 1 von 1
    • Once the nail polish has dried, you may cut any hanging pieces of thread.
    • The nail polish will take about 1 minute to dry.
    • Be sure to complete this step after applying the nail polish and letting it dry or a new run will form.
Abschluss
These steps can save a pair of tights from becoming too tattered for normal use.
3 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team 12-1, Green Winter 2015 Mitglied von Cal Poly, Team 12-1, Green Winter 2015
CPSU-GREEN-W15S12G1
6 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 18
Letzte 30 Tage: 91
Insgesamt: 39,592
