Einleitung
This guide will show you how to remove a cutting from your succulent plant and grow it as a new plant. At least basic previous expertise in gardening will be necessary. Guides such as How to Pot A Plant and How to Care For Succulents may be helpful to the user.
You will need an existing succulent plant as well as the items listed in the tools section, which will be used to create an environment for your new plant. This guide includes directions on how best to cut your succulent to promote growth, how to set up the plant’s new pot for the best drainage, and how to properly water the new succulent to promote root growth while avoiding root rot and/or drowning your plant.
Taking a cutting from your succulent is a good way to maintain the size of your plant so it does not outgrow its pot. It is also a good way to get a second plant! However, you should only try to propagate your succulent if the plant is healthy and mature, otherwise taking a cutting may damage the plant.
Was du brauchst
Fill your new pot with a couple inches of potting soil. A good rule of thumb is to fill the first ⅓ of the pot.
Carefully cut off the piece of the succulent you want to propagate.
When cutting a branch of your succulent, cut it low on the plant so you get a long stem for your cutting.
Gently position your cutting in its new pot.
Fill the pot with an appropriate amount of soil. Your plant should be close enough the top of the pot to obtain sunlight, but deep enough in the soil to be secure.
Add a layer of soil to fill the area around your plant. You have added enough when the roots are buried and the plant can stand upright without tipping over.
As you fill the rest of your pot with soil, you will need to hold your plant steady with one hand. This is because the roots are not yet buried, so the insecure plant will not be able to stand on its own.
After you’ve added a few inches of soil, gently let go of your plant and see if it can remain upright independently.
You may follow the steps in this process again as your plant continues to grow
