Zum Hauptinhalt wechseln
How to Re-Align the Zipper on a Backpack
Was du brauchst
  1. How to Re-Align the Zipper on a Backpack, How to Re-Align the Zipper on a Backpack: Schritt 1, Bild 1 von 1
    • Locate the section of zipper with the problem.
  2. How to Re-Align the Zipper on a Backpack: Schritt 2, Bild 1 von 3 How to Re-Align the Zipper on a Backpack: Schritt 2, Bild 2 von 3 How to Re-Align the Zipper on a Backpack: Schritt 2, Bild 3 von 3
    • Take off the slider by sliding it towards the side without a stopper at the end and pulling it off.
    • Slider: the device that moves up and down the chain to open or close the zipper.
  3. How to Re-Align the Zipper on a Backpack: Schritt 3, Bild 1 von 3 How to Re-Align the Zipper on a Backpack: Schritt 3, Bild 2 von 3 How to Re-Align the Zipper on a Backpack: Schritt 3, Bild 3 von 3
    • Use pliers to remove at least 4 teeth on each side to leave room for a place to sew.
    • Squeezing the handles of the pliers, grab a single zipper tooth and pull it off. This may rip the zipper fabric, but you will sew it together later.
    • Be cautious that you do not get hurt from pulling the pliers back.
    • Small, sharp parts will come off during this procedure. Keep track of these small parts so you can throw them away.
  4. How to Re-Align the Zipper on a Backpack: Schritt 4, Bild 1 von 2 How to Re-Align the Zipper on a Backpack: Schritt 4, Bild 2 von 2
    • Using thread of similar color to the backpack, insert one end of the thread through the eye of the needle.
    • Let the needle slide down the thread until it hangs at the center. You should have two equal lengths of thread on either side of the needle.
  5. How to Re-Align the Zipper on a Backpack: Schritt 5, Bild 1 von 1
    • Tie the loose ends of the thread into a knot
  6. How to Re-Align the Zipper on a Backpack: Schritt 6, Bild 1 von 2 How to Re-Align the Zipper on a Backpack: Schritt 6, Bild 2 von 2
    • Place the slider back on the zipper.
    • The side of the slider that you feed in first has a divider in the middle.
    • Feed in one side of the zipper in at a time and pull it up to see if the slider can zip up the backpack.
  7. How to Re-Align the Zipper on a Backpack: Schritt 7, Bild 1 von 3 How to Re-Align the Zipper on a Backpack: Schritt 7, Bild 2 von 3 How to Re-Align the Zipper on a Backpack: Schritt 7, Bild 3 von 3
    • After putting the slider back on the zipper, sew the ends of the zipper to prevent the slider from sliding off.
    • Insert the needle through one side of the zipper fabric and pull until it stops at the knot.
    • Then, insert the needle through the other side of the zipper fabric and pull tightly until it seems secure.
    • Repeat this step as many times as needed.
  8. How to Re-Align the Zipper on a Backpack: Schritt 8, Bild 1 von 3 How to Re-Align the Zipper on a Backpack: Schritt 8, Bild 2 von 3 How to Re-Align the Zipper on a Backpack: Schritt 8, Bild 3 von 3
    • Tie a knot to finish it off and cut the excess thread with scissors.
  9. How to Re-Align the Zipper on a Backpack: Schritt 9, Bild 1 von 2 How to Re-Align the Zipper on a Backpack: Schritt 9, Bild 2 von 2
    • Tuck the zipper inside the flap of the backpack to cover the end of the zipper.
    • Sew the zipper fabric to the backpack to secure it in place.
Abschluss
Test your zipper to see if it is working properly.
16 weitere Nutzer:innen haben diese Anleitung absolviert.
Emily Liu
557 Reputation
1 Anleitung geschrieben
UC Davis, Team S2-G1, Cole Spring 2017 Mitglied von UC Davis, Team S2-G1, Cole Spring 2017
UCD-COLE-S17S2G1
3 Mitglieder
6 Anleitungen geschrieben
2 Kommentare
Thanks i saved some money doing this myself. Grewt instruction
umchocky - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 87
Letzte 7 Tage: 651
Letzte 30 Tage: 3,326
Insgesamt: 193,636
