Einleitung
Do you need to fix the caulking in your bathroom? Is it old and growing mold? With this guide to re-caulking a bathroom, you can easily fix this problem yourself and make your bathroom a cleaner and nicer area in your home.
Was du brauchst
Use a knife to uproot the old caulk that is sealed to the wall.
Remove all of the residual caulk that lies under the main slabs that were just pulled off.
Before applying the new caulk, clean the area with hydrogen peroxide or rubbing alcohol.
Place the tip of the new bottle of caulk into the hole by the trigger.
Squeeze the trigger to cut.
Push the silver button and pull the spring back to fully open the chamber of the caulking gun.
Place the new bottle of caulk into the open chamber.
To apply the new caulk, press the trigger and drag the gun across the area being re-caulked.
By using these tools and referring to this guide, you can re-caulk any part of your bathroom with relative ease.
5 weitere Nutzer:innen haben diese Anleitung absolviert.
