Einleitung
Welcome to our comprehensive guide on adjusting the bike stand for the URBAN COMMUTER BIKE (Model No. 671060). This guide will help you achieve optimal functionality for your bike stand, whether you are an experienced cyclist or new to bike maintenance. By following this step-by-step tutorial, you will learn how to remove, adjust, and reattach your bike stand with ease. Each step is accompanied by clear instructions and detailed photos to ensure a smooth process.
Before you begin, please note the following tips and warnings:
- Ensure your bike is securely supported to prevent any accidents while adjusting the stand.
- Be cautious of any sharp edges or moving parts that could cause injury.
- If your bike has any electrical components, make sure to disconnect the battery to avoid any electrical hazards.
Let’s dive in and get your bike stand perfectly positioned for your riding pleasure!
Was du brauchst
Einführungsvideo
Remove the bike stand by loosening the bolts connecting it to the frame.
Use a wrench to turn the bolts counterclockwise.
Now that the bolt is loose you should be able to move the bike stand around.
Identify the optimal position for reattaching the stand to avoid interference with pedaling.
Reattach the stand securely to the frame using the same bolts and ensure it is aligned properly.
Eine weitere Person hat diese Anleitung absolviert.
