Zum Hauptinhalt wechseln
How to Realign a Guitar Neck
Was du brauchst
  1. How to Realign a Guitar Neck, How to Realign a Guitar Neck: Schritt 1, Bild 1 von 2 How to Realign a Guitar Neck, How to Realign a Guitar Neck: Schritt 1, Bild 2 von 2
    • Place the guitar on a flat surface.
  2. How to Realign a Guitar Neck: Schritt 2, Bild 1 von 2 How to Realign a Guitar Neck: Schritt 2, Bild 2 von 2
    • Use the tuning pegs to loosen the strings.
  3. How to Realign a Guitar Neck: Schritt 3, Bild 1 von 2 How to Realign a Guitar Neck: Schritt 3, Bild 2 von 2
    • Place the alignment key on the truss rod.
    • The alignment key should fit perfectly on the truss rod in order to align properly.
  4. How to Realign a Guitar Neck: Schritt 4, Bild 1 von 2 How to Realign a Guitar Neck: Schritt 4, Bild 2 von 2
    • Gently turn the tuning key clockwise to increase the distance between the bridge and strings, or counter-clockwise to reduce the distance between the bridge and strings.
    • Twisting the key too hard might break the bridge. The twist should be smooth.
    • After one twist at the rod, be sure to check the bridge to see if it will need more aligning.
  5. How to Realign a Guitar Neck: Schritt 5, Bild 1 von 1
    • Tighten the strings up again using the tuning pegs.
    • Do not over tighten the strings; doing so can cause them to break.
  6. How to Realign a Guitar Neck: Schritt 6, Bild 1 von 2 How to Realign a Guitar Neck: Schritt 6, Bild 2 von 2
    • Tune the guitar using a tuner.
    • Some Dean guitars have a built-in tuner.
Ziellinie
Mahbub Hasan
133 Reputation
1 Anleitung geschrieben
York University, Team 2-16, O'Regan Fall 2021 Mitglied von York University, Team 2-16, O'Regan Fall 2021
YORK-O'REGAN-F21S2G16
1 Mitglied
Ein Kommentar
This is all wrong.
What's being done here is tightening the truss rod, which does NOT align the neck. You cannot change the distance between the bridge and the strings.
You do not want to fool with the truss rod unless you understand what it does and how to tell that you're doing it correctly, and this "guide" does not even begin to explain any of that.
Dan Gellert - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 12
Insgesamt: 1,046
