Zum Hauptinhalt wechseln
How to Reattach Loose Book Pages
Was du brauchst
  1. How to Reattach Loose Book Pages, How to Reattach Loose Book Pages: Schritt 1, Bild 1 von 3 How to Reattach Loose Book Pages, How to Reattach Loose Book Pages: Schritt 1, Bild 2 von 3 How to Reattach Loose Book Pages, How to Reattach Loose Book Pages: Schritt 1, Bild 3 von 3
    • Open the book and remove the loose pages.
    • Make sure the pages are in numerical order.
    • Set the ordered loose pages aside.
  2. How to Reattach Loose Book Pages: Schritt 2, Bild 1 von 3 How to Reattach Loose Book Pages: Schritt 2, Bild 2 von 3 How to Reattach Loose Book Pages: Schritt 2, Bild 3 von 3
    • Squeeze some glue onto the inside of the book spine.
  3. How to Reattach Loose Book Pages: Schritt 3, Bild 1 von 3 How to Reattach Loose Book Pages: Schritt 3, Bild 2 von 3 How to Reattach Loose Book Pages: Schritt 3, Bild 3 von 3
    • Use a craft stick to spread the glue so that it covers the spine evenly.
  4. How to Reattach Loose Book Pages: Schritt 4, Bild 1 von 3 How to Reattach Loose Book Pages: Schritt 4, Bild 2 von 3 How to Reattach Loose Book Pages: Schritt 4, Bild 3 von 3
    • Set the ordered loose pages back in the spine.
    • Carefully line up the top and bottom of each loose page with those in the book.
    • You might need to wiggle or readjust them to make sure they are lined up.
    • Work quickly so that the glue doesn’t dry and cause the pages to stick in the wrong place.
  5. How to Reattach Loose Book Pages: Schritt 5, Bild 1 von 3 How to Reattach Loose Book Pages: Schritt 5, Bild 2 von 3 How to Reattach Loose Book Pages: Schritt 5, Bild 3 von 3
    • Place a rubber band around the book to hold it closed and to ensure pages are held in place.
    • Additionally, you can stack heavier books on top of your repaired book.
    • Let the book dry for 24 hours.
  6. How to Reattach Loose Book Pages: Schritt 6, Bild 1 von 2 How to Reattach Loose Book Pages: Schritt 6, Bild 2 von 2
    • Remove the heavy books and rubber band.
  7. How to Reattach Loose Book Pages: Schritt 7, Bild 1 von 1
    • Gently flip through your book. The pages should feel secure.
    • If the pages don’t feel secure you can repeat steps 1 through 6.
Ziellinie
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Carrie
229 Reputation
1 Anleitung geschrieben
Ein Kommentar
Thank you , very useful . Be Lucky 🍀 Glenn.
chuckle.tometoyou - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 87
Letzte 30 Tage: 470
Insgesamt: 13,297
