Einleitung
Jhumki earrings are common jewellery that tend to break easily due to their weight. This guide is an easy way to fix a jhumki earring that has broken from its stud.
Was du brauchst
Use your hands or small chain nose pliers to twist open the Jhumki jump ring.
Rotate the jump ring to disconnect it from the Jhumki.
Thread the open jump ring through the hoop of the earring.
Carefully twist the jump ring close.
Optional: Cut a small piece of tape.
Carefully flatten the tape on the opening of the open jump ring.
Fast fertig!
Ziellinie
