Einleitung
These instructions provide a simple technique for reattaching a broken piece of wood to any type of furniture. We demonstrate this technique on a nightstand, but it can be used on any wooden surface that needs to be fixed. No carpentry skill is required to complete this repair.
Was du brauchst
Dust the surface of the fragment and the damaged area of the furniture.
Any household cleaner will work; we recommend a damp rag.
Apply glue to both the fragment and the furniture.
Check that the glue is spread evenly throughout both pieces.
Clamp the two pieces together.
You can use any type of clamp that you have on hand. If you don't have a clamp, any type of clip would work.
Wait 30 minutes for the glue to dry before removing the clamp.
Continue using furniture as you had before!
3 weitere Personen haben diese Anleitung absolviert.
3 Kommentare zur Anleitung
The clean and modern design of our products allows you to use the items for years. we are starting to sale small products and want to get your feedback for these products. We are not the World best online store but we want to be and this is only possible with your response and recommendation.
Very easy to follow instructions. I've found the most difficult part of any fence build is getting the posts lined up properly and getting them plumb. Even with a line, it can be tough . https://www.whitewooden.com/
