Zum Hauptinhalt wechseln
How to Reattach a Cabinet's Center Stile
Was du brauchst
  1. How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: Schritt 1, Bild 1 von 3 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: Schritt 1, Bild 2 von 3 How to Reattach a Cabinet's Center Stile, How to Reattach a Cabinet's Center Stile: Schritt 1, Bild 3 von 3
    • Measure the width and length of the detached center stile.
  2. How to Reattach a Cabinet's Center Stile: Schritt 2, Bild 1 von 3 How to Reattach a Cabinet's Center Stile: Schritt 2, Bild 2 von 3 How to Reattach a Cabinet's Center Stile: Schritt 2, Bild 3 von 3
    • Mark the measurements on the wood block that will be the supporting piece.
    • You may need to extend the length of the new stile to cover several inches above and below the stile's point of attachment.
    • Follow the markings and use the hacksaw to cut down the wood block so that it is the same width as the center stile.
  3. How to Reattach a Cabinet's Center Stile: Schritt 3, Bild 1 von 3 How to Reattach a Cabinet's Center Stile: Schritt 3, Bild 2 von 3 How to Reattach a Cabinet's Center Stile: Schritt 3, Bild 3 von 3
    • Apply a generous amount of wood glue to one side of the wood block.
    • Spread the glue to cover the entire side of the wood.
  4. How to Reattach a Cabinet's Center Stile: Schritt 4, Bild 1 von 2 How to Reattach a Cabinet's Center Stile: Schritt 4, Bild 2 von 2
    • Place the wood piece against the back of stile and cabinet frame.
    • Use clamps to hold the center stile, cabinet frame, and wood supporting piece together.
    • The clamps prevent the wood block from sliding off the center stile so that it will dry in a fixed position.
    • Remove the clamps after 24 hours.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 54
Insgesamt: 1,200
