Zum Hauptinhalt wechseln
How to Reattach an Apron Strap
Was du brauchst
  1. How to Reattach an Apron Strap, How to Reattach an Apron Strap: Schritt 1, Bild 1 von 3 How to Reattach an Apron Strap, How to Reattach an Apron Strap: Schritt 1, Bild 2 von 3 How to Reattach an Apron Strap, How to Reattach an Apron Strap: Schritt 1, Bild 3 von 3
    • Use a thread color that matches your article of clothing (or whatever color you like).
    • Cut a piece of thread around 21 centimeters long.
    • Insert one side of the thread in the eye of the sewing needle.
    • You can wet the thread a bit to make it easier to insert in the hole.
    • It may help to thread the needle against a background with a contrasting color to make it easier to see.
  2. How to Reattach an Apron Strap: Schritt 2, Bild 1 von 3 How to Reattach an Apron Strap: Schritt 2, Bild 2 von 3 How to Reattach an Apron Strap: Schritt 2, Bild 3 von 3
    • Pull the thread to make sure it is in the hole.
    • Make sure the apron is aligned correctly.
    • Insert the needle from where you want to start to repair the fabric.
    • Begin from right to left.
  3. How to Reattach an Apron Strap: Schritt 3, Bild 1 von 3 How to Reattach an Apron Strap: Schritt 3, Bild 2 von 3 How to Reattach an Apron Strap: Schritt 3, Bild 3 von 3
    • Once inserted, make a knot so the thread can't move. Pull the thread as far as possible but still able to create a knot.
    • Insert the threaded needle a short distance from where you began, starting again from right to left.
    • Making two knots instead of one is helpful so it can last longer.
  4. How to Reattach an Apron Strap: Schritt 4, Bild 1 von 3 How to Reattach an Apron Strap: Schritt 4, Bild 2 von 3 How to Reattach an Apron Strap: Schritt 4, Bild 3 von 3
    • Use caution when handling a sharp needle.
    • Continue sewing from right to left, starting each new stitch a few centimeters from the previous stitch.
    • Make sure the thread goes all the way through.
  5. How to Reattach an Apron Strap: Schritt 5, Bild 1 von 3 How to Reattach an Apron Strap: Schritt 5, Bild 2 von 3 How to Reattach an Apron Strap: Schritt 5, Bild 3 von 3
    • Once you reach the end of the left side, make two small knots.
    • Begin from the bottom and pull to tighten the knot.
    • The knot should be small and tight enough to not be able to rip.
  6. How to Reattach an Apron Strap: Schritt 6, Bild 1 von 3 How to Reattach an Apron Strap: Schritt 6, Bild 2 von 3 How to Reattach an Apron Strap: Schritt 6, Bild 3 von 3
    • Make sure the knot is not loose.
    • Cut the excess thread with a pair of scissors.
  7. How to Reattach an Apron Strap: Schritt 7, Bild 1 von 3 How to Reattach an Apron Strap: Schritt 7, Bild 2 von 3 How to Reattach an Apron Strap: Schritt 7, Bild 3 von 3
    • Make sure the apron is aligned correctly and not loose from both sides.
    • Tug on the strap to make sure it is not loose.
  8. How to Reattach an Apron Strap: Schritt 8, Bild 1 von 3 How to Reattach an Apron Strap: Schritt 8, Bild 2 von 3 How to Reattach an Apron Strap: Schritt 8, Bild 3 von 3
    • You can iron the apron to make sure it is correctly aligned, but this step is optional.
    • Lay the strap down carefully and iron from the bottom to the top.
Ziellinie
3 weitere Personen haben diese Anleitung absolviert.
CSU Los Angeles, Team S1-G3, Harris Spring 2021 Mitglied von CSU Los Angeles, Team S1-G3, Harris Spring 2021
CSULA-HARRIS-S21S1G3
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 75
Insgesamt: 1,582
