Zum Hauptinhalt wechseln
How to Recaulk a Toilet
Was du brauchst
  1. How to Recaulk a Toilet, Toilet Caulk: Schritt 1, Bild 1 von 3 How to Recaulk a Toilet, Toilet Caulk: Schritt 1, Bild 2 von 3 How to Recaulk a Toilet, Toilet Caulk: Schritt 1, Bild 3 von 3
    • Wet a paper towel with warm water and wipe away any old caulk residue
    • Once all the residue is removed, wipe away the remaining water with a new dry paper towel until the area is completely dry.
  2. How to Recaulk a Toilet: Schritt 2, Bild 1 von 2 How to Recaulk a Toilet: Schritt 2, Bild 2 von 2
    • Using scissors, clip the tip of your caulk tube to it's intended length, which is indicated by a line on the tip of your caulk tube
  3. How to Recaulk a Toilet: Schritt 3, Bild 1 von 2 How to Recaulk a Toilet: Schritt 3, Bild 2 von 2
    • Using gentle pressure and grip, caulk around the entirety of the toilet rim
  4. How to Recaulk a Toilet: Schritt 4, Bild 1 von 3 How to Recaulk a Toilet: Schritt 4, Bild 2 von 3 How to Recaulk a Toilet: Schritt 4, Bild 3 von 3
    • When you're done caulking the entirety of the rim, make soapy water by mixing liquid dish soap and warm water. Then apply the soapy water gently to the rim of the toilet.
    • Using a paper towel, wipe around the rim of to ensure that the caulk is neatly placed around the toilets rim.
  5. How to Recaulk a Toilet: Schritt 5, Bild 1 von 3 How to Recaulk a Toilet: Schritt 5, Bild 2 von 3 How to Recaulk a Toilet: Schritt 5, Bild 3 von 3
    • When you feel the caulk is well laid, wipe up the remaining soapy water with a dry paper towel
Abschluss
After twenty-four hours your toilet will be recalked like new and ready to be used.
Eine weitere Person hat diese Anleitung absolviert.
DaNaria
148 Reputation
1 Anleitung geschrieben
Sam Houston State, Team 1-1, Bennett Fall 2023 Mitglied von Sam Houston State, Team 1-1, Bennett Fall 2023
SHSU-BENNETT-F23S1G1
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 17
Insgesamt: 145
