Zum Hauptinhalt wechseln
How to Recharge the A/C in a 2009 Infiniti G37
Was du brauchst
  1. How to Recharge the A/C in a 2009 Infiniti G37, How to Recharge the A/C in a 2009 Infiniti G37: Schritt 1, Bild 1 von 3 How to Recharge the A/C in a 2009 Infiniti G37, How to Recharge the A/C in a 2009 Infiniti G37: Schritt 1, Bild 2 von 3 How to Recharge the A/C in a 2009 Infiniti G37, How to Recharge the A/C in a 2009 Infiniti G37: Schritt 1, Bild 3 von 3
    • Locate the high and low-pressure ports.
    • The high-pressure port is located on the upper right (below the brake liquid).
    • The low-pressure port is located inside the brake liquid case (remove the case).
  2. How to Recharge the A/C in a 2009 Infiniti G37: Schritt 2, Bild 1 von 3 How to Recharge the A/C in a 2009 Infiniti G37: Schritt 2, Bild 2 von 3 How to Recharge the A/C in a 2009 Infiniti G37: Schritt 2, Bild 3 von 3
    • Connect the hoses to the gauge and the pressure ports.
    • Blue stands for low pressure.
    • Red stands for high pressure.
    • Yellow is where the new air flows through the two hoses.
  3. How to Recharge the A/C in a 2009 Infiniti G37: Schritt 3, Bild 1 von 3 How to Recharge the A/C in a 2009 Infiniti G37: Schritt 3, Bild 2 von 3 How to Recharge the A/C in a 2009 Infiniti G37: Schritt 3, Bild 3 von 3
    • Turn on the engine.
    • Turn the A/C to the maximum capacity.
    • Make sure the pulley belt is spinning smoothly to proceed.
  4. How to Recharge the A/C in a 2009 Infiniti G37: Schritt 4, Bild 1 von 2 How to Recharge the A/C in a 2009 Infiniti G37: Schritt 4, Bild 2 von 2
    • Turn off the vehicle.
    • Connect one end of the tee valve connector to your refrigerant and the other end to the yellow hose.
    • Turn on your vehicle again.
  5. How to Recharge the A/C in a 2009 Infiniti G37: Schritt 5, Bild 1 von 2 How to Recharge the A/C in a 2009 Infiniti G37: Schritt 5, Bild 2 von 2
    • Make sure the high-pressure nob is sealed.
    • Begin to add refrigerant by opening the nob.
    • To get the most refrigerant, shake the bottle side-by-side.
  6. How to Recharge the A/C in a 2009 Infiniti G37: Schritt 6, Bild 1 von 2 How to Recharge the A/C in a 2009 Infiniti G37: Schritt 6, Bild 2 von 2
    • Pump the refrigerant until the pressure gauge gets to 25- 45 psi. This process can take 10 minutes.
    • Do not go past 45 psi as the car can over-charge.
    • If you are using refrigerant mini cans, use the amount the car recommends. You can find this information inside the hood of the vehicle.
  7. How to Recharge the A/C in a 2009 Infiniti G37: Schritt 7, Bild 1 von 2 How to Recharge the A/C in a 2009 Infiniti G37: Schritt 7, Bild 2 von 2
    • Go inside your vehicle and check the temperature.
    • The temperature should be from 35-48 degrees Fahrenheit.
    • If the temperature is over what is recommended, the A/C will just be really cold. This will cause no problems.
    • Now that the temperature and air pressures are set, it's time to turn off your vehicle.
    • Proceed to remove all equipment (use safety gear).
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Brian Canas
145 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team 4-20, Briggs Spring 2022 Mitglied von CSU Los Angeles, Team 4-20, Briggs Spring 2022
CSULA-BRIGGS-S22S4G20
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 45
Letzte 30 Tage: 196
Insgesamt: 3,612
