Zum Hauptinhalt wechseln
How to Recharge the A/C in a 2012 Hyundai Tucson
Was du brauchst
  1. How to Recharge the A/C in a 2012 Hyundai Tucson, How to Recharge the A/C in a 2012 Hyundai Tucson: Schritt 1, Bild 1 von 1
    • Enter the car and turn on the coldest and most powerful A/C you can.
    • Make sure the A/C button is on.
  2. How to Recharge the A/C in a 2012 Hyundai Tucson: Schritt 2, Bild 1 von 1
    • Pop the hood open on the left side of the driver’s seat.
    • Secure the hood with the pole brace found on the left side of the engine near the low pressure fill port.
  3. How to Recharge the A/C in a 2012 Hyundai Tucson: Schritt 3, Bild 1 von 2 How to Recharge the A/C in a 2012 Hyundai Tucson: Schritt 3, Bild 2 von 2
    • Screw the hose to the top of the R134a refrigerant. Screw to the right until failure. Remove low pressure fill cap.
  4. How to Recharge the A/C in a 2012 Hyundai Tucson: Schritt 4, Bild 1 von 2 How to Recharge the A/C in a 2012 Hyundai Tucson: Schritt 4, Bild 2 von 2
    • With the A/C blowing cold and strong, attach the adapter at the end of the hose to the low pressure fill port.
    • Once the adapter is securely fastened, pull and hold the trigger with the bottle upside down.
    • You will begin to feel the bottle get cold. This is the refrigerant becoming activated.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Micah B
109 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 82
Letzte 30 Tage: 280
Insgesamt: 1,764
