Zum Hauptinhalt wechseln
How to Refinish Wood Furniture
Was du brauchst
    1. How to Refinish Wood Furniture, How to Refinish Wood Furniture: Schritt 1, Bild 1 von 2 How to Refinish Wood Furniture, How to Refinish Wood Furniture: Schritt 1, Bild 2 von 2
      • Remove all hardware from the furniture.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Refinish Wood Furniture: Schritt 2, Bild 1 von 1
      • Next you will need to wash any grease or contaminations before sanding.
      • Washing your furniture prior to sanding will prevent dirt, grease, and contaminations from being sanded into the surface of the furniture.
      Frag FixBot
    3. How to Refinish Wood Furniture: Schritt 3, Bild 1 von 1
      • After the surface is dry begin sanding.
      • Remember to only sand with the grain so the sanding scratches will blend in with the grain.
      Frag FixBot
    4. How to Refinish Wood Furniture: Schritt 4, Bild 1 von 1
      • Spray or paint on your primer prior to painting.
      • Remember if using spray paint to apply in a sweeping motion.
      Frag FixBot
    5. How to Refinish Wood Furniture: Schritt 5, Bild 1 von 1
      • After allowing primer to dry approximately 3 hours apply paint. Allow paint 24 hours to dry.
      • If you are able to see the primer mixed in the paint, you may need to apply second coat of paint if needed.
      Frag FixBot
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 27
Insgesamt: 497
