Zum Hauptinhalt wechseln
How to Reinsert a Wooden Chair Side Stretcher
Was du brauchst
    1. How to Reinsert a Wooden Chair Side Stretcher, How to Reinsert a Wooden Chair Side Stretcher: Schritt 1, Bild 1 von 2 How to Reinsert a Wooden Chair Side Stretcher, How to Reinsert a Wooden Chair Side Stretcher: Schritt 1, Bild 2 von 2
      • Use the sandpaper to rough up the empty dowel holes on the side stretcher and the chairs legs.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Reinsert a Wooden Chair Side Stretcher: Schritt 2, Bild 1 von 2 How to Reinsert a Wooden Chair Side Stretcher: Schritt 2, Bild 2 von 2
      • Check if the new dowel fits through the stretcher hole and the leg hole.
      Frag FixBot
    3. How to Reinsert a Wooden Chair Side Stretcher: Schritt 3, Bild 1 von 3 How to Reinsert a Wooden Chair Side Stretcher: Schritt 3, Bild 2 von 3 How to Reinsert a Wooden Chair Side Stretcher: Schritt 3, Bild 3 von 3
      • Using the disposable stirrer and bowl, mix a 2:1 ratio of sawdust and wood glue.
      • The final consistency should be paste-like.
      Frag FixBot
    4. How to Reinsert a Wooden Chair Side Stretcher: Schritt 4, Bild 1 von 3 How to Reinsert a Wooden Chair Side Stretcher: Schritt 4, Bild 2 von 3 How to Reinsert a Wooden Chair Side Stretcher: Schritt 4, Bild 3 von 3
      • With the stirrer, fill in the leg hole of the broken dowel with the paste.
      Frag FixBot
    5. How to Reinsert a Wooden Chair Side Stretcher: Schritt 5, Bild 1 von 2 How to Reinsert a Wooden Chair Side Stretcher: Schritt 5, Bild 2 von 2
      • Apply a glob of wood glue to the other leg's hole.
      • Use the stirrer to spread the glue around the hole.
      Frag FixBot
    6. How to Reinsert a Wooden Chair Side Stretcher: Schritt 6, Bild 1 von 2 How to Reinsert a Wooden Chair Side Stretcher: Schritt 6, Bild 2 von 2
      • Insert the intact stretcher dowel into the leg hole with wood glue.
      Frag FixBot
    7. How to Reinsert a Wooden Chair Side Stretcher: Schritt 7, Bild 1 von 2 How to Reinsert a Wooden Chair Side Stretcher: Schritt 7, Bild 2 von 2
      • Align the empty stretcher hole to the the leg hole filled with paste.
      • Insert the dowel and firmly push it in till it's fully submerged into the stretcher hole.
      • Insertion of the dowel will push out some of the wood paste.
      Frag FixBot
    8. How to Reinsert a Wooden Chair Side Stretcher: Schritt 8, Bild 1 von 2 How to Reinsert a Wooden Chair Side Stretcher: Schritt 8, Bild 2 von 2
      • Put the legs holding the stretcher between the bar clamp's jaws.
      • Screw in the handle to clamp together the legs until it is secure.
      • Putting a cloth or barrier between the clamp and the leg can prevent possible damage to the wood's surface.
      Frag FixBot
    9. How to Reinsert a Wooden Chair Side Stretcher: Schritt 9, Bild 1 von 1
      • Remove any wood glue or paste residue on the legs and stretcher with a damp paper towel.
      Frag FixBot
    10. How to Reinsert a Wooden Chair Side Stretcher: Schritt 10, Bild 1 von 1
      • Leave the chair and bar clamp in place for 24 hours while the wood glue and paste cures.
      • After waiting, screw out the clamp's handle to remove it from the chair.
      Frag FixBot
Abschluss
Your chair should now resemble how it was before, with the side stretcher back in place. Happy fixing!
Eine weitere Person hat diese Anleitung absolviert.
Shaelyn
205 Reputation
1 Anleitung geschrieben
UC Davis, Team 3-6, Andersen Winter 2024 Mitglied von UC Davis, Team 3-6, Andersen Winter 2024
UCD-ANDERSEN-W24S3G6
2 Mitglieder
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 15
Letzte 30 Tage: 67
Insgesamt: 1,241
