Zum Hauptinhalt wechseln
How to Remove Cutting Board Scratches
Was du brauchst
  1. How to Remove Cutting Board Scratches, How to Remove Cutting Board Scratches: Schritt 1, Bild 1 von 1
    • Thoroughly wash the cutting board with warm water and gentle dish soap.
    • Rinse the cutting board to make sure all the soap is removed.
    Frag FixBot
    Kommentar hinzufügen
  2. How to Remove Cutting Board Scratches: Schritt 2, Bild 1 von 1
    • Pat the cutting board dry with a towel.
    • Allow the cutting board to completely air dry.
    Frag FixBot
  3. How to Remove Cutting Board Scratches: Schritt 3, Bild 1 von 1
    • Use a fine grit sandpaper (220-grit) and gently sand the scratched sections of the board.
    • Use even pressure until the scratches disappear.
    Frag FixBot
  4. How to Remove Cutting Board Scratches: Schritt 4, Bild 1 von 1
    • Remove any dust or residue using a damp towel.
    • Make sure the cutting board is completely clean and dry before moving on to the next step.
    Frag FixBot
  5. How to Remove Cutting Board Scratches: Schritt 5, Bild 1 von 1
    • Pour a generous amount of food-safe oil onto the surface of the board.
    • The amount will vary depending on the size of the board.
    • Allow the oil to soak into the cutting board overnight.
    • Wipe off any excess oil.
    • If there are still scratches visible on the cutting board, repeat all steps if necessary.
    Frag FixBot
Ziellinie
Eine weitere Person hat diese Anleitung absolviert.
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 15
Letzte 30 Tage: 86
Insgesamt: 879
