Zum Hauptinhalt wechseln
How to Remove Rust from a Gardening Shovel
Was du brauchst
  1. How to Remove Rust from a Gardening Shovel, How to Remove Rust from a Gardening Shovel: Schritt 1, Bild 1 von 1
    • Fill a large container with water.
  2. How to Remove Rust from a Gardening Shovel: Schritt 2, Bild 1 von 1
    • Add an ample amount of distilled white vinegar.
  3. How to Remove Rust from a Gardening Shovel: Schritt 3, Bild 1 von 1
    • Soak the shovel for at least 10 minutes, but ideally for 24 hours.
  4. How to Remove Rust from a Gardening Shovel: Schritt 4, Bild 1 von 1
    • Scrub the shovel with a scrub brush.
    • Scrub with a tooth brush.
    • Scrub with a Brillo pad.
  5. How to Remove Rust from a Gardening Shovel: Schritt 5, Bild 1 von 1
    • Refill the large container with fresh water.
  6. How to Remove Rust from a Gardening Shovel: Schritt 6, Bild 1 von 1
    • Add 1-2 cups of baking soda.
  7. How to Remove Rust from a Gardening Shovel: Schritt 7, Bild 1 von 1
    • Soak the shovel for 15 minutes.
  8. How to Remove Rust from a Gardening Shovel: Schritt 8, Bild 1 von 1
    • Rinse the shovel.
  9. How to Remove Rust from a Gardening Shovel: Schritt 9, Bild 1 von 1
    • Dry the shovel completely.
  10. How to Remove Rust from a Gardening Shovel: Schritt 10, Bild 1 von 1
    • Oil the shovel with coconut oil.
Abschluss
Repeat process until rust is completely removed.
Brigette B
181 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 9
Insgesamt: 112
