Zum Hauptinhalt wechseln
How to Remove Stickers From a Car
Was du brauchst
  1. How to Remove Stickers From a Car, How to Remove Stickers From a Car: Schritt 1, Bild 1 von 1
    • First of all, find the area where the sticker is. In my case, it is on the car body near the fuel tank.
  2. How to Remove Stickers From a Car: Schritt 2, Bild 1 von 2 How to Remove Stickers From a Car: Schritt 2, Bild 2 von 2
    • Spray the area with some soap water or with cleaning sprays.
  3. How to Remove Stickers From a Car: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Microfiber Cleaning Cloths
    $3.99
    Kaufen
    • Next, wipe the area thoroughly with a microfiber cleaning cloth.
  4. How to Remove Stickers From a Car: Schritt 4, Bild 1 von 2 How to Remove Stickers From a Car: Schritt 4, Bild 2 von 2
    • Turn on the hairdryer and put it in its hot setting.
    • Start heating the sticker from a few inches away. Try to heat the sticker from the center outward.
    • This will soften the adhesive under the sticker and make the following steps much easier.
  5. How to Remove Stickers From a Car: Schritt 5, Bild 1 von 3 How to Remove Stickers From a Car: Schritt 5, Bild 2 von 3 How to Remove Stickers From a Car: Schritt 5, Bild 3 von 3
    Plastic Cards
    $2.99
    Kaufen
    • Use a plastic card and try to scrape the sticker from the edges.
    • A plastic card can help you remove your unwanted stickers without damaging the paint.
    • If it doesn't work, try to repeat step 4 and then try again.
    • If you are working on a glass surface, use a razor blade instead of a plastic card! It may seem too much for the glass, but the glass is hard enough to use a razor blade on.
    • Be careful when using a razor blade!
  6. How to Remove Stickers From a Car: Schritt 6, Bild 1 von 2 How to Remove Stickers From a Car: Schritt 6, Bild 2 von 2
    • Finally, if there is any residue, heat the residue with the hairdryer and scrape it off with a plastic card or razor blade (depending on where the sticker is).
    • After removing all stickers and residue, use some detailing spray or cleaning spray to clean the area again and you are all set!
Abschluss
After these steps, you should have a clean surface without any residues!
Xuanfang Gao
141 Reputation
1 Anleitung geschrieben
York University, Team E-7, Melo-Thaiss Fall 2021 Mitglied von York University, Team E-7, Melo-Thaiss Fall 2021
YORK-MELO-THAISS-F21SEG7
1 Mitglied
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 39
Insgesamt: 679
