Einleitung
Over time, if worn excessively, a Pandora silver bracelet can tarnish. If it is placed under water too often or if worn in humid places, the bracelet can soon tarnish and lose its shine. Once Pandora bracelets are tarnished, they become less appealing to wear and can be expensive to replace with a new one.
This guide will help you to remove any tarnish build up on a Pandora silver bracelet. The guide below is also applicable towards any Pandora charms that also have tarnished along with the bracelet.
Was du brauchst
Take your bracelet and find the barrel clasp at the bottom.
Remove any charms on your bracelet and place them separately (they can also be cleaned if applicable).
Grab any small bowl and place a medium sized sheet of aluminum foil over it.
Place your bracelet into the aluminum-covered bowl.
Heat 1 cup of water in the microwave for 2 minutes.
Add that cup of hot water to your aluminum covered bowl.
Add ¼ teaspoon of baking soda into your bowl with the hot water and bracelet.
Mix the baking soda until it is dissolved into your bowl completely.
After scrubbing, grab a towel and dry the bracelet entirely.
Make sure to dry the inside of the barrel clasp to prevent future tarnish build up.
