Zum Hauptinhalt wechseln
How to Remove The Logitech K120's Keycaps
Was du brauchst
  1. How to Remove The Logitech K120's Keycaps, Removing The Small Keycaps: Schritt 1, Bild 1 von 2 How to Remove The Logitech K120's Keycaps, Removing The Small Keycaps: Schritt 1, Bild 2 von 2
    • For small keycaps (1st image), the only tool needed is a spudger. Pry the keycap off by wedging a spudger beneath the key and prying up. (Shown in 2nd image)
    • Preferably, use a plastic spudger. A metal spudger may damage the keycap.
  2. How to Remove The Logitech K120's Keycaps, Removing Large Keycaps: Schritt 2, Bild 1 von 2 How to Remove The Logitech K120's Keycaps, Removing Large Keycaps: Schritt 2, Bild 2 von 2
    • When removing large keycaps (shown in image 1), a metal bracket connects the keycap to the front chassis. (Image 2) Use a spudger to separate the bracket from the keycap.
Abschluss
The key caps on the Logitech K120 keyboard are very easy to remove, you just need to pry a bit.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Marcus Jones
1.115 Reputation
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 10
Letzten 7 Tage: 65
Letzten 30 Tage: 350
Insgesamt: 8,475
