Zum Hauptinhalt wechseln
How to Remove Wax From Clothing
Was du brauchst
  1. How to Remove Wax From Clothing, Removing Dried Wax: Schritt 1, Bild 1 von 1
    • Set up the ironing board.
    • Plug in the iron and turn it on.
    • Your iron may need some time to heat up, especially if it is an older model.
  2. How to Remove Wax From Clothing: Schritt 2, Bild 1 von 1
    • Place your piece of clothing onto the ironing board.
  3. How to Remove Wax From Clothing: Schritt 3, Bild 1 von 2 How to Remove Wax From Clothing: Schritt 3, Bild 2 von 2
    • Take your brown paper bag and fold it over the affected area, being sure to cover both sides of the waxy clothing.
  4. How to Remove Wax From Clothing: Schritt 4, Bild 1 von 1
    • Press the iron on top of the brown paper bag.
    • Move the iron around as if you are ironing wrinkles out.
    • Be careful not to burn your fingers.
  5. How to Remove Wax From Clothing: Schritt 5, Bild 1 von 2 How to Remove Wax From Clothing: Schritt 5, Bild 2 von 2
    • Lift up the brown paper bag once it looks like the oil has saturated the bag.
    • Repeat steps 3-5 with new bags, until the remainder of the wax is soaked up.
  6. How to Remove Wax From Clothing: Schritt 6, Bild 1 von 1
    • Feel free to wash your item now that the wax is removed, just as you normally would.
Abschluss
To finish getting wax out it is not a bad idea to wash your item, if possible, in a washing machine for a clothing item or use carpet wash for the carpet.
Molly Green
133 Reputation
1 Anleitung geschrieben
UW Tacoma, Team S1-G7, Cardinal Spring 2020 Mitglied von UW Tacoma, Team S1-G7, Cardinal Spring 2020
UWT-CARDINAL-S20S1G7
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 42
Insgesamt: 540
