Zum Hauptinhalt wechseln
How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation)
Was du brauchst
  1. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 1, Bild 1 von 2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation), How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 1, Bild 2 von 2
    • On the top of the printer, turn the injector counter-clockwise and pull the tab.
  2. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 2, Bild 1 von 3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 2, Bild 2 von 3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 2, Bild 3 von 3
    • Insert your fingers in the center of the filament cartridge and slowly pull it away from the printer.
  3. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 3, Bild 1 von 1
    • Place the cartridge face up and pry off the lid of the cartridge.
  4. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 4, Bild 1 von 2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 4, Bild 2 von 2
    • Gently flip the cartridge on its front and remove the two 2mm Hex screws using a Hex key.
  5. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 5, Bild 1 von 1
    • Flip the cartridge face up and remove the gearbox and extractor tube.
  6. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 6, Bild 1 von 3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 6, Bild 2 von 3 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 6, Bild 3 von 3
    • Place your thumb on the front of the injector head and your middle finger on the needle.
    • Firmly pull the needle towards your thumb until the injector head cases cracks and pulls apart the case.
  7. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 7, Bild 1 von 2 How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 7, Bild 2 von 2
    • Heat the needle using a lighter, making sure that the flame does not touch the needle.
    • Using needle-nose pliers, pull the needle from the tube.
    • Do not touch the needle as it may still be hot.
  8. How to Remove a Filament Clog on a Cubify Cube 3D Printer (3rd Generation): Schritt 8, Bild 1 von 1
    • Insert a paper clip and turn until the clog is removed.
Abschluss
Hector Vazquez
157 Reputation
1 Anleitung geschrieben
CSU Los Angeles, Team S12-G11, Harris Fall 2020 Mitglied von CSU Los Angeles, Team S12-G11, Harris Fall 2020
CSULA-HARRIS-F20S12G11
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 18
Insgesamt: 527
