Einleitung
Text books face a lot of wear and tear and by the end of the semester their covers can be ragged. This simple and cheap fix will help those covers look like new again and prevent further damage.
Was du brauchst
Lay the ConTact Paper on a smooth, clean surface.
Place your book on the ConTact paper.
Wrap the ConTact Paper over your book, measuring out enough to completely cover the book.
Place a paperweight on the side of the folded paper to prevent curling. Or even the scissors you're using (as shown) to hold down the corner of the paper.
Flatten the edge of the ConTact Paper along the spine of your book.
Cut the ConTact Paper from the roll, keeping to the length measured to cover your entire book.
Once the extra ConTact Paper is discarded, cut the ConTact Paper diagonally towards the spine of your book.
Repeat this cut on the other side of the spine.
Your finished cut should have a 'v' shape pointing towards the spine of the book
With the cover of your book laying flat against the left side of the paper, peel back the right half of the paper from the laminate film.
Fold the edge of the laminate film onto the table to prevent sliding and bubbles.
Place the top edge of your book to the top edge of the center of the laminate film.
Using a rolling motion, slowly stick the rest of the spine to the laminate.
Using the same motion, slowly roll one side of the textbook over the exposed film.
Fold the edges onto the inside cover of the textbook. Start with the top of the book cover, folding the vertical edge of the book last.
Remove the rest of the paper from the laminate film.
Repeat motions from step 7 and slowly roll your book cover onto the laminate film.
Repeat steps 8 and 9 to cut and secure lamination.
Trim any remaining lamination film to complete the project.
If you have followed the previous steps, your textbook should now be mended and resistant to further damage.
Eine weitere Person hat diese Anleitung absolviert.
