Zum Hauptinhalt wechseln
How to Repair A Damaged Book Cover
Was du brauchst
  1. How to Repair A Damaged  Book Cover, How to Repair A Damaged  Book Cover: Schritt 1, Bild 1 von 1
    • Lay the ConTact Paper on a smooth, clean surface.
    • Make sure the adhesive side is face down so that the white paper is facing you.
    • Place your book on the ConTact paper.
  2. How to Repair A Damaged  Book Cover: Schritt 2, Bild 1 von 1
    • Wrap the ConTact Paper over your book, measuring out enough to completely cover the book.
  3. How to Repair A Damaged  Book Cover: Schritt 3, Bild 1 von 1
    • Place a paperweight on the side of the folded paper to prevent curling. Or even the scissors you're using (as shown) to hold down the corner of the paper.
    • Flatten the edge of the ConTact Paper along the spine of your book.
  4. How to Repair A Damaged  Book Cover: Schritt 4, Bild 1 von 1
    • Cut the ConTact Paper from the roll, keeping to the length measured to cover your entire book.
  5. How to Repair A Damaged  Book Cover: Schritt 5, Bild 1 von 3 How to Repair A Damaged  Book Cover: Schritt 5, Bild 2 von 3 How to Repair A Damaged  Book Cover: Schritt 5, Bild 3 von 3
    • Once the extra ConTact Paper is discarded, cut the ConTact Paper diagonally towards the spine of your book.
    • Repeat this cut on the other side of the spine.
    • Your finished cut should have a 'v' shape pointing towards the spine of the book
  6. How to Repair A Damaged  Book Cover: Schritt 6, Bild 1 von 3 How to Repair A Damaged  Book Cover: Schritt 6, Bild 2 von 3 How to Repair A Damaged  Book Cover: Schritt 6, Bild 3 von 3
    • With the cover of your book laying flat against the left side of the paper, peel back the right half of the paper from the laminate film.
    • Make sure to peel the paper back until the focal point of the 'V' is exposed.
    • Fold the edge of the laminate film onto the table to prevent sliding and bubbles.
  7. How to Repair A Damaged  Book Cover: Schritt 7, Bild 1 von 3 How to Repair A Damaged  Book Cover: Schritt 7, Bild 2 von 3 How to Repair A Damaged  Book Cover: Schritt 7, Bild 3 von 3
    • Place the top edge of your book to the top edge of the center of the laminate film.
    • Using a rolling motion, slowly stick the rest of the spine to the laminate.
    • Using the same motion, slowly roll one side of the textbook over the exposed film.
    • Roll onto the laminate slowly and evenly to prevent bubbles in your lamination.
  8. How to Repair A Damaged  Book Cover: Schritt 8, Bild 1 von 2 How to Repair A Damaged  Book Cover: Schritt 8, Bild 2 von 2
    • Unfold the laminate from the table and cut to the edges similar to Step 4
    • The finished edges will look like an inverted 'v'
  9. How to Repair A Damaged  Book Cover: Schritt 9, Bild 1 von 3 How to Repair A Damaged  Book Cover: Schritt 9, Bild 2 von 3 How to Repair A Damaged  Book Cover: Schritt 9, Bild 3 von 3
    • Fold the edges onto the inside cover of the textbook. Start with the top of the book cover, folding the vertical edge of the book last.
  10. How to Repair A Damaged  Book Cover: Schritt 10, Bild 1 von 3 How to Repair A Damaged  Book Cover: Schritt 10, Bild 2 von 3 How to Repair A Damaged  Book Cover: Schritt 10, Bild 3 von 3
    • Remove the rest of the paper from the laminate film.
    • Repeat motions from step 7 and slowly roll your book cover onto the laminate film.
  11. How to Repair A Damaged  Book Cover: Schritt 11, Bild 1 von 3 How to Repair A Damaged  Book Cover: Schritt 11, Bild 2 von 3 How to Repair A Damaged  Book Cover: Schritt 11, Bild 3 von 3
    • Repeat steps 8 and 9 to cut and secure lamination.
    • Trim any remaining lamination film to complete the project.
Abschluss
If you have followed the previous steps, your textbook should now be mended and resistant to further damage.
Eine weitere Person hat diese Anleitung absolviert.
Missouri Western, Team S40-G7, Kunkel Spring 2017 Mitglied von Missouri Western, Team S40-G7, Kunkel Spring 2017
MWSU-KUNKEL-S17S40G7
2 Mitglieder
3 Anleitungen geschrieben
Ein Kommentar
The original cover was completely destroyed by water and am unable to follow your instructions. Can't I just purchase a new cover?
ryanmary - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 9
Letzte 7 Tage: 35
Letzte 30 Tage: 143
Insgesamt: 16,963
