Zum Hauptinhalt wechseln
How to Repair A Scuffed Dress Shoe
Was du brauchst
  1. How to Repair A Scuffed Dress Shoe, How to Repair A Scuffed Dress Shoe: Schritt 1, Bild 1 von 3 How to Repair A Scuffed Dress Shoe, How to Repair A Scuffed Dress Shoe: Schritt 1, Bild 2 von 3 How to Repair A Scuffed Dress Shoe, How to Repair A Scuffed Dress Shoe: Schritt 1, Bild 3 von 3
    • Remove the laces from your shoe.
    • This allows you to clean more surface area that laces usually block.
  2. How to Repair A Scuffed Dress Shoe: Schritt 2, Bild 1 von 3 How to Repair A Scuffed Dress Shoe: Schritt 2, Bild 2 von 3 How to Repair A Scuffed Dress Shoe: Schritt 2, Bild 3 von 3
    • Clean your shoe, removing any dust or dirt that may be stuck to its surface.
    • This can be done with a cloth or damp paper towel.
  3. How to Repair A Scuffed Dress Shoe: Schritt 3, Bild 1 von 3 How to Repair A Scuffed Dress Shoe: Schritt 3, Bild 2 von 3 How to Repair A Scuffed Dress Shoe: Schritt 3, Bild 3 von 3
    • Locate the scuffed areas and apply a generous amount of polish to your cotton cloth.
    • Most shoe polish will easily stain, clothing, carpet, and generally anything it gets on. It's recommended putting a towel, or disposable materials underneath to prevent damage.
  4. How to Repair A Scuffed Dress Shoe: Schritt 4, Bild 1 von 3 How to Repair A Scuffed Dress Shoe: Schritt 4, Bild 2 von 3 How to Repair A Scuffed Dress Shoe: Schritt 4, Bild 3 von 3
    • Using your cotton cloth, carefully dip it in water, then firmly press the cloth where the polish is applied.
    • Buff the location.
    • You do not need to use a separate cloth for this process. In fact its better to use the same cloth for both the water and the shoe shine.
    • A good strategy when buffing is to rotate the cloth in little circles while pressing against the shoe. You will need to spend approximately 2-3 minutes, for every inch of material, or until satisfied.
  5. How to Repair A Scuffed Dress Shoe: Schritt 5, Bild 1 von 2 How to Repair A Scuffed Dress Shoe: Schritt 5, Bild 2 von 2
    • Apply another coat of shoe polish as needed. If you are finished, continue ahead.
    • Wipe the area; using a clean cloth and let it sit out to dry.
    • You should set the shoe out in an open and ventilated area.
  6. How to Repair A Scuffed Dress Shoe: Schritt 6, Bild 1 von 2 How to Repair A Scuffed Dress Shoe: Schritt 6, Bild 2 von 2
    • After following the previous steps, you can reapply as needed until the scuffed area matches the surrounding materials.
    • If you do not have corframs (high gloss) shoes, you may need to shine more then just the scuffed area to ensure it matches the surrounding materials.
Abschluss
To get your laces back onto your shoe. Put them back, in the reverse direction you took them out.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 19
Letzte 30 Tage: 132
Insgesamt: 3,634
