Zum Hauptinhalt wechseln
How to Repair A Wet Book
Was du brauchst
  1. How to Repair A Wet Book, How to Repair A Wet Book: Schritt 1, Bild 1 von 1
    • Be cautious when handling wet books, as books are very fragile when wet and you can accidentally damage front cover, pages, and/or spine.
    • If you do not have time to fix it, immediately put it in a Ziplock bag and place in freezer until you're ready. When you are ready to fix it, lay it on the table and leave it until it thaws.
    • Cover table with plastic sheet or newspapers.
  2. How to Repair A Wet Book: Schritt 2, Bild 1 von 1
    • Lay the book down with the front cover facing up. Place a paper towel over the cover and gently press down on the book.
  3. How to Repair A Wet Book: Schritt 3, Bild 1 von 2 How to Repair A Wet Book: Schritt 3, Bild 2 von 2
    • Be very careful when opening the book, as the spine is very fragile.
    • Gently opening the book to a shallow angle, place paper towels every 10-20 pages in the front half of the book. Place a paper towel on the front cover and press down gently.
  4. How to Repair A Wet Book: Schritt 4, Bild 1 von 2 How to Repair A Wet Book: Schritt 4, Bild 2 von 2
    • Similarly to step 3, gently open the book to a shallow angle and place paper towels in every 10-20 pages towards the last half of the book. Place a paper towel on the front cover and press down.
  5. How to Repair A Wet Book: Schritt 5, Bild 1 von 1
    • Stand the book up, heads or tails, with the pages fanned out.
  6. How to Repair A Wet Book: Schritt 6, Bild 1 von 1
    • To speed up the drying process, leave a fan blowing on it.
  7. How to Repair A Wet Book: Schritt 7, Bild 1 von 2 How to Repair A Wet Book: Schritt 7, Bild 2 von 2
    • If after the book has dried the pages are wavy, lay the book flat and place a board on top of it, along with a couple of heavy books (on top of the board) to help flatten them out. Leave it like this until the pages are completely flattened.
  8. How to Repair A Wet Book: Schritt 8, Bild 1 von 1
    • Great job! The book is now restored to its original condition. Happy reading!
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Lizzy Cox
187 Reputation
1 Anleitung geschrieben
2 Kommentare
because im in middle school. and it is sters full with wet books
Hazen Harwood - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 38
Insgesamt: 985
