Einleitung
Liquid lipstick dried out? Don’t want to throw it out? This simple guide will help you repair that liquid lipstick in 30 minutes or less so that you can continue to wear it without it having to go to waste.
Was du brauchst
Fill a bowl full of warm to hot water and place off to the side for later.
Tighten the cap on the liquid lipstick to prevent water from going inside while the lipstick is submerged in the bowl of water.
Take one pipe cleaner and wrap it all the way around the seal of the liquid lipstick cap to help prevent water from entering the lipstick.
Wrap a second pipe cleaner one to two times around the first pipe cleaner.
Submerge the liquid lipstick into the warm water.
Leave the liquid lipstick in the water for 25-30 minutes.
After the 25-30 minutes are up, remove the liquid lipstick.
Shake the liquid lipstick tube to make sure the lipstick has liquified again or you can take the wand and mix it around inside of the tube instead.
Eine weitere Person hat diese Anleitung absolviert.
