Einleitung
This guide shows users how to repair the damaged playing surface of their LP records through a technique involving coating the record with wood glue. This will improve the record's sound quality, and is ideal for older, worn-out records.
Was du brauchst
Create a solution of 2 parts water to 1 part rubbing alcohol.
Using a paper towel, lightly brush the record with this solution.
Place the record on a record player, then turn on the record player so it rotates.
With a note card, apply the wood glue so that it covers the entire record surface.
Turn the record player off after you apply the wood glue.
Let the record sit for 12 hours to dry.
After 12 hours, check to see the wood glue has dried.
If it has dried, use the tape as a “handle” to peel the glue off.
If the wood glue is not yet dry, check back once every hour until it has dried.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
