Einleitung
The Maytag MRT311FFFE refrigerator vents are located in the freezer compartment and circulate cold air to the refrigerator. When items in the freezer block the vents, the airflow is disrupted, and ice often accumulates in the vents. As a result, the refrigerator doesn’t cool well. This guide will show the process of dismantling and clearing the vent for the correction of airflow, keeping your fridge and freezer cold.
Was du brauchst
Set the temperature switch in the refrigerator to “OFF.”
Use a 6 mm Allen key to remove the two 6.0 mm screws securing the freezer’s interior back cover.
Gently pull the freezer’s interior back cover and set it face down on the bottom of the freezer.
Turn the hairdryer onto its "hot" or "warm" setting, then point it directly into the frozen ventilator’s compartments until the ice melts, clearing the vents.
Replace the back cover.
Reinstall the two 6 mm screws with a 6 mm Allen key.
Replace the freezer shelf.
Your fridge should now be able to maintain cold temperatures again!
