Zum Hauptinhalt wechseln
How to Repair Minor Cricket Bat Damage
Was du brauchst
  1. How to Repair Minor Cricket Bat Damage, How to Repair Minor Cricket Bat Damage: Schritt 1, Bild 1 von 2 How to Repair Minor Cricket Bat Damage, How to Repair Minor Cricket Bat Damage: Schritt 1, Bild 2 von 2
    • Examine the damage on the bat in the images provided.
    • This guide is aimed at fixing cracks and fractures no bigger than what is shown.
  2. How to Repair Minor Cricket Bat Damage: Schritt 2, Bild 1 von 3 How to Repair Minor Cricket Bat Damage: Schritt 2, Bild 2 von 3 How to Repair Minor Cricket Bat Damage: Schritt 2, Bild 3 von 3
    • First, you will want to smooth out the cracks and fractures on the front of the bat.
    • Use the palm sander or sandpaper to go over the affected cracks in a circular motion.
    • Avoid sanding the backside of the bat.
    • Run your hand over the sanded area. It should look lighter in color and feel smooth.
  3. How to Repair Minor Cricket Bat Damage: Schritt 3, Bild 1 von 3 How to Repair Minor Cricket Bat Damage: Schritt 3, Bild 2 von 3 How to Repair Minor Cricket Bat Damage: Schritt 3, Bild 3 von 3
    • Next, we will need a pen or a pencil to create markings on the bat. We will also need a measuring tape or ruler.
    • Measure 3cm from the bottom of the bat (also known as the "toe".)
    • Draw a straight line across the bat at the 3cm mark.
    • Next, measure 5cm from the bottom of the bat.
    • Draw a straight line across the bat at the 5cm mark.
    • The outcome should be 2 parallel lines, no more than 2cm apart.
  4. How to Repair Minor Cricket Bat Damage: Schritt 4, Bild 1 von 3 How to Repair Minor Cricket Bat Damage: Schritt 4, Bild 2 von 3 How to Repair Minor Cricket Bat Damage: Schritt 4, Bild 3 von 3
    • Apply Gorilla Wood Glue between the 2 parallel lines.
    • Spread it out evenly on both the front and back of the bat.
    • Wrap the nylon thread on top of the glue, starting at one parallel line and making your way toward the other line.
    • Be sure to thread the area so it's evenly dispersed.
    • Pull tightly so the nylon thread is snug.
    • Hold the bat in the center to help rotate it as you wrap the thread around.
    • By wrapping the nylon thread around the bat, it prevents the bat from further splitting.
  5. How to Repair Minor Cricket Bat Damage: Schritt 5, Bild 1 von 3 How to Repair Minor Cricket Bat Damage: Schritt 5, Bild 2 von 3 How to Repair Minor Cricket Bat Damage: Schritt 5, Bild 3 von 3
    • Reapply Gorilla Wood Glue on top of the threaded work to secure it.
    • Wait 10-15 minutes to dry completely before the next step.
    • Please clean and dry your hands before continuing with this repair.
  6. How to Repair Minor Cricket Bat Damage: Schritt 6, Bild 1 von 3 How to Repair Minor Cricket Bat Damage: Schritt 6, Bild 2 von 3 How to Repair Minor Cricket Bat Damage: Schritt 6, Bild 3 von 3
    • Next, we will need the heavy-duty scotch tape.
    • Mark with your finger where we ended our thread at the 5cm point.
    • From where your finger is, place the edge of the tape beneath the threaded area and continue pulling it down towards the handle.
    • The tape only needs to be where the ball would hit the bat, so avoid taping on the handle or on the back of the bat.
    • Do this repeatedly until the face of the bat is covered.
  7. How to Repair Minor Cricket Bat Damage: Schritt 7, Bild 1 von 3 How to Repair Minor Cricket Bat Damage: Schritt 7, Bild 2 von 3 How to Repair Minor Cricket Bat Damage: Schritt 7, Bild 3 von 3
    • Check your bat for these three flaws: loose nylon thread, overhanging tape, and sharp corners.
    • If there are no flaws, you have successfully repaired the minorly damaged cricket bat.
Abschluss
Hopefully, this guide will have helped you maintain the life of your cricket bat for many more games to come!
Majjid
145 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 23
Insgesamt: 240
