Einleitung
The purpose of this guide is to help with the common issue first time builders face, that of accidentally breaking a piece of your kit. Through this guide you will be able to fix any would-be mistakes you might have made during building. Thankfully, there are no particular hazards, so there’s no need to worry about any potential dangers during the repair process. Just take each step slow, and you’ll have a repaired part in no time.
Was du brauchst
Identify the original look of your part. This can most easily be done by simply taking the two broken pieces and fitting them together, but if needed, consult the instruction manual that came with your model kit.
Apply a thin coating of Tamiya instant cement to both broken ends of the part.
Attach the pieces together and try to align them as best as you can.
Let the piece dry for approximately five minutes.
Grab one of the empty plastic frames (runners) that came with your kit, preferably one of the same color as your piece.
File or clip down a piece of the runner to use as support.
In this guide, we will be clipping the part for support as the piece is too small to fit a filed down support piece.
Take the cut out piece/pieces of the plastic frame and place them inside of the piece to act as support.
Try to make the support as snug as possible inside of the piece for the best results.
Apply a final thin layer of Tamiya cement to the support piece to make sure it stays in place.
Let the cement dry for about five minutes.
Wait for the glue to dry and you’ll be able to build with it as intended.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
