Zum Hauptinhalt wechseln
How to Repair Scratches in Laminate Finish Furniture
Was du brauchst
    1. How to Repair Scratches in Laminate Finish Furniture, How to Repair Scratches in Laminate Finish Furniture: Schritt 1, Bild 1 von 1
      • Clean the scratched area with a damp cloth or paper towel to remove any dust or debris.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Repair Scratches in Laminate Finish Furniture: Schritt 2, Bild 1 von 1
      • Apply a small amount of wood filler to a putty knife.
      • The amount of wood filler needed may vary depending on severity of the scratches.
      Frag FixBot
    3. How to Repair Scratches in Laminate Finish Furniture: Schritt 3, Bild 1 von 1
      • Spread the wood filler over the scratches using the putty knife until they are sufficiently filled in.
      • The putty knife can be used to scrape away excess wood filler and smooth the surface.
      Frag FixBot
    4. How to Repair Scratches in Laminate Finish Furniture: Schritt 4, Bild 1 von 1
      • Wipe away any residual wood filler from the surface using a damp cloth or paper towel.
      Frag FixBot
    5. How to Repair Scratches in Laminate Finish Furniture: Schritt 5, Bild 1 von 1
      • Allow the wood filler to dry completely based on the package instructions before resuming use.
      Frag FixBot
    6. How to Repair Scratches in Laminate Finish Furniture: Schritt 6, Bild 1 von 1
      • Sand over the wood filler using fine-grit sandpaper if a smoother finish is desired.
      Frag FixBot
    7. How to Repair Scratches in Laminate Finish Furniture: Schritt 7, Bild 1 von 1
      • Paint over the wood filler, if desired, to color match the filler with the furniture.
      • Wood filler comes in a variety of colors so painting may not be necessary.
      Frag FixBot
Ziellinie
Shelby
145 Reputation
1 Anleitung geschrieben
University of Arizona, Team 2-2, Cools Stephens Spring 2024 Mitglied von University of Arizona, Team 2-2, Cools Stephens Spring 2024
ARIZONA-COOLS STEPHENS-S24S2G2
2 Mitglieder
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 25
Letzte 30 Tage: 86
Insgesamt: 1,967
