Einleitung
Faux leather items, such as purses, can become damaged over time from regular wear, scratches, or pet claws.
This guide shows how to use a leather repair kit to repair a faux leather purse damaged by a cat’s claws. It covers filling and smoothing small holes to restore the surface. A color guide is helpful when mixing repair compounds to closely match the original material. This method works for both faux leather and real leather.
This repair requires patience and can be messy, especially on larger damaged areas. Be sure to work in a well-ventilated area to avoid breathing fumes from the repair paste.
Was du brauchst
Inspect the damaged area to determine how much of the paste you need to make.
Spray a paper towel with all-purpose cleaning spray.
Clean the damaged area with a paper towel.
Mix the paste from the assorted compounds in the mixing jar with the applicator brush to achieve the correct color matching the faux leather.
Using the color guide, select a primary color on the left and a secondary color at the bottom to achieve the desired middle tone.
Use a small spatula to apply the mixed paste to the damaged area and backing fabric. Smooth and thin the paste to your liking.
Wait several hours for the area to dry, and your item will be ready to use again.
After your repair, let it air-dry for roughly 2-24 hours, depending on the amount of paste applied. Reapply as much paste as necessary to repair the damage after the paste has fully dried.
