Zum Hauptinhalt wechseln
How to Repair a Belt Loop on Dress Pants
Was du brauchst
    1. How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: Schritt 1, Bild 1 von 3 How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: Schritt 1, Bild 2 von 3 How to Repair a Belt Loop on Dress Pants, How to Repair a Belt Loop on Dress Pants: Schritt 1, Bild 3 von 3
      • Thread the sewing machine with a thread that matches your pants.
      • Thread via your sewing machine instructions. They can be marked on your machine, or in a separate pamphlet.
      Frag FixBot
      Kommentar hinzufügen
    2. How to Repair a Belt Loop on Dress Pants: Schritt 2, Bild 1 von 3 How to Repair a Belt Loop on Dress Pants: Schritt 2, Bild 2 von 3 How to Repair a Belt Loop on Dress Pants: Schritt 2, Bild 3 von 3
      • Remove the extension table from the sewing machine.
      Frag FixBot
    3. How to Repair a Belt Loop on Dress Pants: Schritt 3, Bild 1 von 1
      • Pin the belt loop seam side up so that the top of the loop is 1/4 inch above the seam.
      Frag FixBot
    4. How to Repair a Belt Loop on Dress Pants: Schritt 4, Bild 1 von 3 How to Repair a Belt Loop on Dress Pants: Schritt 4, Bild 2 von 3 How to Repair a Belt Loop on Dress Pants: Schritt 4, Bild 3 von 3
      • Sew using a straight stitch along the seam.
      • Use the reverse feature on the sewing machine to go over the stitches three times.
      • Once the sewing foot is down and the needle is in the fabric you can remove the pin.
      Frag FixBot
    5. How to Repair a Belt Loop on Dress Pants: Schritt 5, Bild 1 von 3 How to Repair a Belt Loop on Dress Pants: Schritt 5, Bild 2 von 3 How to Repair a Belt Loop on Dress Pants: Schritt 5, Bild 3 von 3
      • Remove the pants from the sewing machine by cutting the threads.
      Frag FixBot
    6. How to Repair a Belt Loop on Dress Pants: Schritt 6, Bild 1 von 1
      • Fold the interfacing over so that it is out of the way of the needle.
      • If the pants do not have interfacing, this step can be skipped.
      Frag FixBot
    7. How to Repair a Belt Loop on Dress Pants: Schritt 7, Bild 1 von 2 How to Repair a Belt Loop on Dress Pants: Schritt 7, Bild 2 von 2
      • Sew the belt loop a 1/4 inch below the seam using a straight stitch.
      • Use the reverse feature to go over the stitches three times.
      Frag FixBot
    8. How to Repair a Belt Loop on Dress Pants: Schritt 8, Bild 1 von 1
      Frag FixBot
    9. How to Repair a Belt Loop on Dress Pants: Schritt 9, Bild 1 von 1
      • Fold the belt loop over.
      Frag FixBot
    10. How to Repair a Belt Loop on Dress Pants: Schritt 10, Bild 1 von 3 How to Repair a Belt Loop on Dress Pants: Schritt 10, Bild 2 von 3 How to Repair a Belt Loop on Dress Pants: Schritt 10, Bild 3 von 3
      • Trim the belt loop's excess length so that there is a 1/4 inch overlap.
      Frag FixBot
    11. How to Repair a Belt Loop on Dress Pants: Schritt 11, Bild 1 von 1
      • Pin the folded belt loop to the top of the waistband.
      Frag FixBot
    12. How to Repair a Belt Loop on Dress Pants: Schritt 12, Bild 1 von 2 How to Repair a Belt Loop on Dress Pants: Schritt 12, Bild 2 von 2
      • Sew the top of the belt loop with an 1/8 inch seam allowance, using a straight stitch.
      • Use the reverse feature on the sewing machine and go over the stitches three times.
      Frag FixBot
    13. How to Repair a Belt Loop on Dress Pants: Schritt 13, Bild 1 von 3 How to Repair a Belt Loop on Dress Pants: Schritt 13, Bild 2 von 3 How to Repair a Belt Loop on Dress Pants: Schritt 13, Bild 3 von 3
      Frag FixBot
    14. How to Repair a Belt Loop on Dress Pants: Schritt 14, Bild 1 von 1
      • Trim any remaining threads.
      Frag FixBot
Ziellinie
Allyson Lahnala
229 Reputation
1 Anleitung geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 38
Insgesamt: 849
