Einleitung
This step by step guide demonstrates the repair of a bra's underwire poking through the underside of the cup.
Was du brauchst
Locate the problem: find where the underwire breaks through the fabric of the bra.
Measure the appropriate length of thread and cut it.
Thread the needle and pull both ends evenly to double up the thread.
Tie the two loose ends of the thread together with a simple knot.
Place the fabric over the hole. Sew along the perimeter of the fabric square with a simple overlock stitch.
In the last stitch, leave a loop of tread and pull the needle through the loop.
Finish by tying a knot in the end of the tread.
Cut the excess thread close to the fabric.
Cut the excess fabric off the finished patch.
Inspect the patch to make sure it is securely sewed on the bra.
The final product should be a small patch on the inside of the cup.
5 weitere Personen haben diese Anleitung absolviert.
2 Kommentare
You made something that is a total pain in the #$@ not so painful anymore and thanks for adding the video cause that helped a lot
I agree with Wllow. Thank you on behalf of my wife and wallet.
