Einleitung
If you accidentally break your beautiful 3-wick candle and cannot burn it because the jar is heavily damaged. then this guide is for you. This guide will help you save money from buying a new candle and protect the environment from chemical reactions that candle wax causes in the landfill.
This guide requires you to use your stove to melt the candle (from Step 3 to Step 5). Use oven mitts or potholders to handle the cooking pot after it has been heated.
Was du brauchst
Cut the candle wax into small cubes and remove the wicks.
Melt the wax over medium heat and stir frequently with a wooden spoon until all the candle wax completely melts.
Place the wicks into glass jars, and secure the candle wicks by sticking the wick taps to bottom of the jars.
Using a pair of oven mitts or pot holders, pour the melted wax into the glass jars.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
