Zum Hauptinhalt wechseln
How to Repair a Broken Jump Ring
Was du brauchst
  1. How to Repair a Broken Jump Ring, How to Repair a Broken Jump Ring: Schritt 1, Bild 1 von 1
    • Firmly grasp the broken jump ring using one set of small needle-nose pliers.
    • Make sure that the ring's opening is not blocked by the pliers.
  2. How to Repair a Broken Jump Ring: Schritt 2, Bild 1 von 1
    • Grasp the opposite side of the jump ring with your other pair of small needle noise pliers.
  3. How to Repair a Broken Jump Ring: Schritt 3, Bild 1 von 1
    • Gently twist the pliers in opposite directions until the gap is wide enough to reattach the jump ring to the ear wire.
  4. How to Repair a Broken Jump Ring: Schritt 4, Bild 1 von 2 How to Repair a Broken Jump Ring: Schritt 4, Bild 2 von 2
    • Grasp the ear wire (if applicable) and insert its loop into the opening of the jump ring.
  5. How to Repair a Broken Jump Ring: Schritt 5, Bild 1 von 2 How to Repair a Broken Jump Ring: Schritt 5, Bild 2 von 2
    • Insert your earring into the opening of the jump ring.
  6. How to Repair a Broken Jump Ring: Schritt 6, Bild 1 von 2 How to Repair a Broken Jump Ring: Schritt 6, Bild 2 von 2
    • Grasp the jump ring between your two pairs of pliers and push/twist the two ends of the ring toward each other, until the two ends meet and the gap is closed.
    • Make sure that the gap is closed tight!
Abschluss
Your earrings are ready to be worn again!
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 10
Letzte 30 Tage: 35
Insgesamt: 1,015
