Zum Hauptinhalt wechseln
How to Repair a Broken Slider on a Suitcase Zipper
Was du brauchst
  1. How to Repair a Broken Slider on a Suitcase Zipper, Slider on a Zipper: Schritt 1, Bild 1 von 1
    • Locate the zipper with the broken slider on the suitcase.
  2. How to Repair a Broken Slider on a Suitcase Zipper: Schritt 2, Bild 1 von 2 How to Repair a Broken Slider on a Suitcase Zipper: Schritt 2, Bild 2 von 2
    • Find the top of the zipper and locate the two stop pieces.
  3. How to Repair a Broken Slider on a Suitcase Zipper: Schritt 3, Bild 1 von 2 How to Repair a Broken Slider on a Suitcase Zipper: Schritt 3, Bild 2 von 2
    • Use your pliers to remove both of the stop pieces from the zipper.
    • Be careful to not tear the zipper fabric when removing the stop pieces.
  4. How to Repair a Broken Slider on a Suitcase Zipper: Schritt 4, Bild 1 von 3 How to Repair a Broken Slider on a Suitcase Zipper: Schritt 4, Bild 2 von 3 How to Repair a Broken Slider on a Suitcase Zipper: Schritt 4, Bild 3 von 3
    • Remove the original slider from the zipper.
  5. How to Repair a Broken Slider on a Suitcase Zipper: Schritt 5, Bild 1 von 2 How to Repair a Broken Slider on a Suitcase Zipper: Schritt 5, Bild 2 von 2
    • Attach the new slider to the zipper.
    • You may need to use some force to get the new zipper slider onto the zipper itself.
  6. How to Repair a Broken Slider on a Suitcase Zipper: Schritt 6, Bild 1 von 3 How to Repair a Broken Slider on a Suitcase Zipper: Schritt 6, Bild 2 von 3 How to Repair a Broken Slider on a Suitcase Zipper: Schritt 6, Bild 3 von 3
    • Attach two new stop pieces with a pair of pliers.
    • Use the pliers to crimp the stop pieces into the fabric.
    • The best area to place the stop pieces is directly above the first few teeth of the zipper.
  7. How to Repair a Broken Slider on a Suitcase Zipper: Schritt 7, Bild 1 von 2 How to Repair a Broken Slider on a Suitcase Zipper: Schritt 7, Bild 2 von 2
    • Check to make sure the zipper works by moving the slider up and down.
Ziellinie
Demetria
145 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 4
Letzte 7 Tage: 25
Letzte 30 Tage: 69
Insgesamt: 1,192
