Zum Hauptinhalt wechseln
How to Repair a Broken/Cracked Soccer Shin Pad
Was du brauchst
  1. How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: Schritt 1, Bild 1 von 3 How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: Schritt 1, Bild 2 von 3 How to Repair a Broken/Cracked Soccer Shin Pad, How to Repair a Broken/Cracked Soccer Shin Pad: Schritt 1, Bild 3 von 3
    • Start by properly cleaning the dirt off the soccer shin pad with a coarse brush.
    • Be sure to clear any dust from inside the crack as well, as any dirt left inside can interfere with the bonding agent
  2. How to Repair a Broken/Cracked Soccer Shin Pad: Schritt 2, Bild 1 von 1
    • Put one clamp on either side of the crack.
  3. How to Repair a Broken/Cracked Soccer Shin Pad: Schritt 3, Bild 1 von 1
    • Align the clamps so that there are no spaces throughout the crack.
  4. How to Repair a Broken/Cracked Soccer Shin Pad: Schritt 4, Bild 1 von 2 How to Repair a Broken/Cracked Soccer Shin Pad: Schritt 4, Bild 2 von 2
    • Make sure clamps are aligned with the crack before you apply the resin solution
    • Apply the resin solution onto the crack, being sure to fully cover the crack on both sides.
    • Let the solution dry for at least 30 minutes.
    • But we suggest leaving the shin pad out for 24 hours for best results.
  5. How to Repair a Broken/Cracked Soccer Shin Pad: Schritt 5, Bild 1 von 3 How to Repair a Broken/Cracked Soccer Shin Pad: Schritt 5, Bild 2 von 3 How to Repair a Broken/Cracked Soccer Shin Pad: Schritt 5, Bild 3 von 3
    • Remove the clamps slowly so that no damage will be done to the shin pad.
  6. How to Repair a Broken/Cracked Soccer Shin Pad: Schritt 6, Bild 1 von 2 How to Repair a Broken/Cracked Soccer Shin Pad: Schritt 6, Bild 2 von 2
    • Clean the extra resin solution that sits on top of the shin pad.
    • Your shin pad is now ready to use.
Ziellinie
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 7
Letzte 30 Tage: 11
Insgesamt: 293
