Zum Hauptinhalt wechseln
How to Repair a Damaged Action Figure
Was du brauchst
  1. How to Repair a Damaged Action Figure, How to Repair a Damaged Action Figure: Schritt 1, Bild 1 von 1
    • Clean the figurine and wash your hands before starting.
  2. How to Repair a Damaged Action Figure: Schritt 2, Bild 1 von 1
    • Identify the broken parts and apply a small drop of super glue on the area needing a fix.
    • CAUTION: AVOID DIRECT SKIN CONTACT WITH THE GLUE. Glue can cause skin irritation or burns.
  3. How to Repair a Damaged Action Figure: Schritt 3, Bild 1 von 2 How to Repair a Damaged Action Figure: Schritt 3, Bild 2 von 2
    • Press the two pieces together and make sure they match. Hold them together tightly for 2 minutes.
    • If any glue leaks outside when pressing, use an alcohol wipe to clean it.
  4. How to Repair a Damaged Action Figure: Schritt 4, Bild 1 von 1
    • Let the glue settle and dry for a minimum of 1 hour.
  5. How to Repair a Damaged Action Figure: Schritt 5, Bild 1 von 1
    • Use acrylic paint as necessary for patching chipped sections of the plastic.
  6. How to Repair a Damaged Action Figure: Schritt 6, Bild 1 von 1
    • Allow the paint to fully dry before attempting to move or adjust the figurine.
    • You can use hair dryer to speed up the drying process.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
UC Davis, Team 3-8, Andersen Winter 2023 Mitglied von UC Davis, Team 3-8, Andersen Winter 2023
UCD-ANDERSEN-W23S3G8
4 Mitglieder
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 7
Letzte 7 Tage: 25
Letzte 30 Tage: 75
Insgesamt: 1,658
