Zum Hauptinhalt wechseln
How to Repair a Hole in the Wall Using Spackle
Was du brauchst
  1. How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: Schritt 1, Bild 1 von 3 How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: Schritt 1, Bild 2 von 3 How to Repair a Hole in  the Wall Using Spackle, How to Repair a Hole in  the Wall Using Spackle: Schritt 1, Bild 3 von 3
    • Prepare the damaged surface by cleaning and removing all dust and debris.
    • If the surface has a wallpaper, remove it for a length more extensive than the mesh patch.
  2. How to Repair a Hole in  the Wall Using Spackle: Schritt 2, Bild 1 von 3 How to Repair a Hole in  the Wall Using Spackle: Schritt 2, Bild 2 von 3 How to Repair a Hole in  the Wall Using Spackle: Schritt 2, Bild 3 von 3
    • Apply the self-Adhesive patch by peeling back the paper liner from the patch and apply it over the hole.
    • Press patch firmly to ensure a strong bond to the wall.
  3. How to Repair a Hole in  the Wall Using Spackle: Schritt 3, Bild 1 von 3 How to Repair a Hole in  the Wall Using Spackle: Schritt 3, Bild 2 von 3 How to Repair a Hole in  the Wall Using Spackle: Schritt 3, Bild 3 von 3
    • Open container and mix spackling compound before applying.
    • Mix thoroughly to have a smooth application.
  4. How to Repair a Hole in  the Wall Using Spackle: Schritt 4, Bild 1 von 3 How to Repair a Hole in  the Wall Using Spackle: Schritt 4, Bild 2 von 3 How to Repair a Hole in  the Wall Using Spackle: Schritt 4, Bild 3 von 3
    • Use the putty knife to spread spackling compound evenly over the adhesive patch.
    • Spread the spackling mixture beyond the area intended to cover.
    • Apply thinner layers toward the edges of the patch, so the patched area blends with the wall.
  5. How to Repair a Hole in  the Wall Using Spackle: Schritt 5, Bild 1 von 2 How to Repair a Hole in  the Wall Using Spackle: Schritt 5, Bild 2 von 2
    • Allow the compound to dry completely before moving to the last step.
    • Depending on the hole's size and thickness of the layers applied, it might take a while to dry.
  6. How to Repair a Hole in  the Wall Using Spackle: Schritt 6, Bild 1 von 3 How to Repair a Hole in  the Wall Using Spackle: Schritt 6, Bild 2 von 3 How to Repair a Hole in  the Wall Using Spackle: Schritt 6, Bild 3 von 3
    • Once the spackling compound has dried, sand it lightly with a sand pad/sponge.
    • Smooth out any bumps on the surface.
    • Do not sand down to mesh patch.
    • Once the surface is smooth, paint, wallpaper, or apply any texture desire.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
York University, Team S1-G17, Melo-Thaiss Winter 2021 Mitglied von York University, Team S1-G17, Melo-Thaiss Winter 2021
YORK-MELO-THAISS-W21S1G17
1 Mitglied
2 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 36
Letzte 30 Tage: 195
Insgesamt: 3,988
